User22451
02:59 AM
- Email to a Friend
Dear Community,
Hi, to all
I want to test desat pin function without any kind circuit?
Is there any approach for test only fault section without connecting igbt/mosfet to it?
Hi, to all
12:50 AM
- Email to a Friend
The desat pin of 1ed family can be tested as follows,
" For this testing the desat pin external circuit (cap, resistor and diode) is still required. If you give an ON signal to the driver and reverse bias that DESAT diode, the constant current source will will eventually charge up the desat capacitor and trigger DESAT protection. This step is similar to the case that when a short circuit is happening and the Vce(sat) is too high and not able to clamp (bring down) the desat pin voltage."
Abhilash P
Abhilash P
12:50 AM
- Email to a Friend
Abhilash P
Abhilash P
User22451
01:03 AM
- Email to a Friend
hey,
Thanks, Abhilash P for the reply. I have another doubt about which type of cap we have to use electrolyte, ceramic, or titanium.
12:59 AM
- Email to a Friend
It can only be a ceramic capacitor. This is because the range of capacitance for this is in several hundreds pF.
Abhilash P
Abhilash P
