User17934
04:59 AM
- Email to a Friend
I am struggling to configure my gate driver with other parameters then the default ones via the registers.
I have the Infineon Motor Control Kit with an Aurix TC234 µC and the TLE9180D-31QK gate driver.
Can someone explain how to calculate the CRC8 of the signature byte (frame with address 00 and name "Configuration Signature")?
Unfortunately I did not find any information in the manual. I would welcome any application note regarding an implementation of this gate driver.
Thank you
Jerome Gossmann
Thank you
Jerome Gossmann
10:20 AM
- Email to a Friend
Hi Jerome,
Sorry for the late reply and thanks for your query.
As stated in the data Sheet of TLE9180D the CRC8 is calculated with the polynomial x^8+x^6+x^3+x^2+1.
Further information can be shared under NDA. Kindly contact the respective Infineon sales or application engineer in your region.
You can also send an email to srivatsa.raghunath@infineon.com and I will connect you to the right gate driver team here in Infineon.
Thanks and regards,
Srivatsa
Thanks and regards,
Srivatsa
User17934
11:16 PM
- Email to a Friend
I have a question regarding the gains of the three current sense amplifiers (CSAs) of the TLE9180D-31QK. As background, I am using a 1 mOhm shunt resistor and a CSA offset of 2.5V is selected.
How can I calculate the expected voltage outputs (VO1 - VO3), which have a limited range of 0 to 5 V, with the 2 CSA gains? Is the voltage signal measured at the shunt multiplied by the two gains and than the offset of 2.5V is added or is there another formula?
Jerome Gossmann
Jerome Gossmann
10:20 AM
- Email to a Friend
Hi Jerome,
Thanks and regards,
Srivatsa
Thanks and regards,
Srivatsa
