Hi everyone,
I'm looking for the best Gate Driver for the IRF200P222. I will use it at 110V (for a 20KW BLDC ESC).
Any advice on which to use ?
Thank you !
Sebastien
Hi Sebastien,
Welcome to Infineon Developer Community,
It is recommended that you can use 1EDB8275F. And you can refer to the 1EDB8275F datasheet for further details at the link https://www.infineon.com/dgdl/Infineon-1EDB8275F-DataSheet-v02_02-EN.pdf?fileId=8ac78c8c7d0d8da4017d...
And share another file Gate Driver Selection Guide for your reference.
Rachel
Hi Sebastien,
Rachel
