User20516
Dear infineon team,
For the development of a heating driver for a battery management system I need a gate driver, which has both an overtemperature shutdown and an overcurrent shutdown.
In your inventory of gate drivers I came across the MOSFET driver AUIR3200S. That would be exactly what I would need just in a little different.
Do you have a low side MOSFET driver with protection and diagnostics in your range, which is automotive certified for controlling an N-channel MOSFET?
Thank you for your response.
AZIZ_HASSAN
250 sign-ins 100 solutions authored 250 replies posted
Thank you for posting on Infineon community.
Yes automotive grade drivers IC are available. I have attached the link where you could find a suitable driver as per your rating and feature requirement.
https://www.infineon.com/cms/en/product/power/gate-driver-ics/automotive-gate-driver-ics/
BR,
AZIZ HASSAN
I
AZIZ_HASSAN
BR,
AZIZ HASSAN
I
