I have one customer using this item for a battered BLDC motor drive.
Battery can reach voltage as low as 7VDC and it worked fine with AUIRS20302S.
However, AUIRS20302S was discontinued at 02/07/2018.
Is there any alternative available?
Kapucija
First solution authored
Is this an automotive application or are you just using an automotive qualified driver?
Kapucija
