Miyata
Distributor - TED (Japan)
First comment on KBA 25 replies posted 10 solutions authored
My customer is now considering to use 6EDL7141.
However if MCU has limitation of SPI I/F port, they rather want to choose I2C type interface.
Do you have I2C interface type of 6EDL7141?  If you have it, pls let me know the part number.
Appreciate for your support!
Thanks & b.regards,
Koji Miyata of TED
SuhasBobade
100 sign-ins 50 replies posted 25 solutions authored
Hi Miyata,
Thanks for the post.
As of now, we don't have an I2C interface type of 6EDL7141.
The current version is provided only with an integrated SPI interface.
If you are unable to change MCU, try using I2C Bus to SPI Bridge interface IC.
Kindly feel free to ask if you need any other information.
Thanking you!
SuhasBobade
Hi Miyata,
Thanking you!
Miyata
Thanks for your quick response.
Could you pls let me know the specific part number of I2C Bus to SPI Bridge interface IC
which customer can use with 6EDL7141?  Is it from NXP? TI?  Microchip?
Thanks & b.regards,
Koji Miyata of TED
SuhasBobade
Hi Miyata,
Thanks for writing us back.
Here we just want to understand, what is the reason for not choosing a MCU with SPI capability. If you can share more details about the project, we can serve you in better way.
XMC1404 MCU with SPI capability is compatible with 6EDL7141. We recommend to use this part.
Thanking you.
Miyata
We are the distributor to IFX and of  we'd like to sell your MCU. Unfortunately, the customer has already decided which MCU to use.  So cannot change it.  That's why we'd like to design win at least 6EDL7141 in customer's design and want to know the specific part number of I2C Bus to SPI Bridge interface IC.  Pls understand customer's and my situation.
Thanks & b.regards,
Koji Miyata of TED
SuhasBobade
Hi Miyata,
We can understand your situation.
You can go with NXP's part but we haven't tested any.
Evaluation needs to be done at customer's end.
Thanking you!
