User22587
5 sign-ins First question asked Welcome!
In the BPA Motor control GUI software (v1.3.0 64bit), using the stand-alone configurator, the PWM MODE configuration register, related to the configuration "1PWM with hall sensor", displays the message "not possible due to interconnections - do not use" (see image attached). Can you explain to me the problem?
Vinay
50 solutions authored 100 replies posted 250 sign-ins
Hello @User22587,
Good Day!
MOTIX gate driver 6EDL7141 can work with 1 PWM mode with Hall sensors. As the BPA motor control GUI is for both 6EDL7141 and IMD700A, for IMD700A PWM signals from XMC controller are interconnected to 6EDL7141, so it's not possible in IMD700A. But in standalone 6EDL7141, we can use 1 PWM mode with hall sensors.
Thank you!
Vinay
Vinay
Dear @User22587,
Good Day!
Thanks for posting your question in Infineon community.
We are working on your query. In the data sheet, 1 PWM mode with hall sensor is present and the truth table for the gate signals is given. But in the BPA motor control GUI, it's mentioned as not possible due to interconnection - do not use. We forwarded your query to internal team, will update you once we get the update from internal team.
Thank you!
Vinay
Vinay
Hello @User22587,
Good Day!
Thank you!
Vinay
