TJ__
5 replies posted 10 sign-ins First reply posted
There is an over current protection feature for this gate driver IC.
If I'm not using this OCP+CSO feature, since we are using MCU to detect and control. Do I simply use a large resistance (~1M?) or can I leave the pins (ITRIP, ITRIP CONF, CSO GAIN, CSO) open, unconnected?
Thank you.
Best Regards.
AZIZ_HASSAN
5 likes given 250 sign-ins 100 solutions authored
In case you are not using the pins, you can keep the pins to ground or connect to very large resistor value.
Thanks and regards,
AZIZ
AZIZ_HASSAN
Thanks and regards,
AZIZ
