2EDS8265HXUMA3 , 2EDS8265HXUMA2 difference
KeTs_2342536
Distributor - Arrow(GC)
First like given 50 sign-ins First comment on blog
What is different between 2EDS8265HXUMA3 and 2EDS8265HXUMA2    ?
Regard,
Kevin
Malleswararao
10 likes received 25 replies posted 10 solutions authored
hi Kevin @KeTs_2342536 ,
thanks for posting your question in the Infineon community.
may I know where did you get the data for "2EDS8265HXUMA3 "?
Can you share the datasheet here to check and update you?
Because, when I check the datasheet and as well as in the website I did not find any data related to "2EDS8265HXUMA3 ".
Malleswararao
Malleswararao
Malleswararao
KeTs_2342536
Hi Malleswararao,
PREVIEW
I saw at Infineon system, have no datasheet also.
Kevin
Malleswararao
hi Kevin @KeTs_2342536,
can you re send the message.
The picture/message is not uploaded correctly and it is not visible.
Malleswararao
