Bandarikarthik
10 questions asked 50 sign-ins 25 sign-ins
Hai
     i am developing a 3.3Kw PFC unit, in that i am using the 2EDN8524F as a gate dreiver for to drive 2 mosfets( in parallel-IPP60R080P7 or IPW60R037P7) but in our testing surpricingly mosfets are safe but this driver IC is failing after 3hrs.
what will be the problem.
for your refference i am attaching the drive part. for this concept we have considered the app note Capture.JPG
Bandari Karthik Kumar
Meghana
10 likes given 250 sign-ins 50 solutions authored
Hello Karthik,
Can you please elaborate a bit more? When you say the driver is failing, what is the exact observation? Which part of the IC is failing? Is it Primary or secondary side?
Also please share us the measurements of INx and OUTx pins if you have a working board.
Meghana
Meghana
Hello @Bandarikarthik ,
Can you please update us on our previous query.
Meghana
