User22878
5 replies posted Welcome! First question asked
Does the 2EDL05N06PF chip include overcurrent protection, overload protection, overvoltage protection, and undervoltage protection? Does it contain the above four functions?
Hello @User22878
The SO8 package gate drivers will not have OCP(Over current protection). Please use the SO14 Package
device that is 2EDL23N06PJ.
Note : Over loading and over temperature are function of current
Guru
User22878
If not, do you recommend other Infineon driver chips in the same package?
Guru_Prasad
250 replies posted 100 solutions authored 25 likes received
Hello @User22878
Thanks for posting  your question Infineon community
The 2EDL05N06PF does not have overcurrent protection and overload protection. This device is having only
under voltage. The over-voltage protection not required.
Please let me know your requirement we will help you with right device.
Guru
User22878
If I want it (2EDL05N06PF) to have overcurrent protection and overload protection, what should I do? I need your professional advice because I like this driver IC from Infineon
User22878
In other words, you can also recommend your other products, I need a driver chip with over-current protection, overload protection, over-voltage protection, under-voltage protection, over-temperature protection, SO8 package
Hello @User22878
Guru
User22878
Regarding the overvoltage protection function of the 2EDL05N06PF you mentioned, I didn't see it in the datasheet, can you point it out to me? Thanks.
Guru_Prasad
Hello @User22878
Generally, we will not consider Overvoltage(OV) on the Gate driver side. we will consider OV at the power supply side itself, not the gate driver side.
Guru
