Aug 17, 2022
06:54 AM
Aug 17, 2022
06:54 AM
I've been designing a half-bridge using the 2EDF7275K as the gate driver. However while attempting to simulate the drive in LTspice I get a missing sub circuit error for the part:
If possible could you confirm that the model works on your end. I would like to confirm if this is a problem with the model or with LTspice/my setup.
Labels
ispn:20082:1:0
l1:144:1:0
l2:1244:1:0
08:07 PM
Aug 18, 2022
08:07 PM
Hi there,
most probably the file is not compatible with Ltspice, you could try running in Simmetrix tool.
08:07 PM
Aug 18, 2022
08:07 PM
Hi there,
