Hi
Can I use 2ED2304S06F to drive IHW20N65R5 IGBTs?
Can I use the 2ED2304S06F driver with an STM32G0 series microcontroller?
Note: STM32G0 works with 3.3v.
@KULCU ,
Can I use 2ED2304S06F to drive IHW20N65R5 IGBTs? -->yes, sure. 2ED2304S06F can be used
to drive an N-channel power MOSFET or IGBT in the high side configuration which operates up to 650 V.
--> 2ED2304S06F trigger logic inputs are compatible with standard CMOS or LSTTL logic down to 3.3 V, so it's ok to work with STM32G0.
@KULCU ,
Thank you for your interest.
