yang
25 sign-ins 10 questions asked 5 replies posted
采用2ED21824S06J驱动IGBT IKB40N65EH5时不论如何调整栅极驱动参数相电流总存在噪声,波形及PCB布局如下,这种现象该如何让解决?
yifei_y
25 likes received 100 solutions authored 100 sign-ins
可以先从优化layout开始。地要大面积铺铜以屏蔽噪声,输入和输出信号分开布线不交叉,分别安排在驱动芯片两端。HIN、LIN连接的电阻要尽可能离引脚近,驱动芯片输出到IGBT栅极要尽可能短以减少寄生电感,Rgate离栅极要近。
可以参考以下文档
https://www.infineon.com/dgdl/Infineon-ApplicationNote_GateDriver_MOSFET_PCB_layout_guidelines_for_M...
https://www.infineon.com/dgdl/Infineon-GateDriverICs_EiceDRIVER_2EDi_Using_the_EiceDRIVER_2EDi_famil...
https://www.infineon.com/dgdl/Infineon-EiceDRIVER_1EDN_TDI_1EDNx550-ApplicationNotes-v02_00-EN.pdf?f...
yifei_y
可以参考以下文档
