- Email to a Friend
Hello IFXer,
How to know the current required by the external converter of the 1EDI20N12AF according to the following condition?
Fs 60kHz
Src. / Sink current 4A/4A
VDD1 3.3V
VDD2 18V
MOSFET Qg 150nC
ex.
Pd = fs * Qg * V * Rg = 60kHz * 150nC * 18V * 3.3ohm = 0.55W
I = Pd / V = 0.55W / 18V = 30mA
- Email to a Friend
You can use the below approach to calculate the current drawn from the secondary side. The current drawn from the secondary side is the sum of quiescent current and gate charging current. Quiescent current is already specified in the datasheet. Only gate charging current has to be calculated. Gate charging current is shown in fig. Calculate the average current from the below waveform.
Please use our simulation models to calculate the current in different conditions. This provides more accurate results than the hand calculations, since this current depends on many factors like Temp, MOSFET, Rg etc.
Also adding the link for the gate resistor calculation for the power device.
Coming to your formula, there is an additional R in the Pd formula given by you. If you add an R, LHS unit and RHS unit will not match. Power dissipation should be Pd = fs * Qg * V
Pd = fs * Qg * V = (1/Second)*(Coulomb)*(Volt) = (Coulomb/Second)*Volt = Ampere * Volt = Watts
Power dissipation on the Rg_ext and Rg int can be calculated as below.
Pd_Rg_ext = fs * Qg * V * ( Rg_ext /(Rg_ext + Rg_int))
Pd_Rg_int = fs * Qg * V * ( Rg_int /(Rg_ext + Rg_int))
Basically we are multiplying the voltage across the resistor and current.
To get the voltage across the resistor , we need to multiply the supply voltage against the voltage divider ratio made by R_ext and R_int.
Hope this explanation helps you,
If you have further questions, please let me know.
Thank you
Vishnu Nambrath
- Email to a Friend
Thank you
Vishnu Nambrath
