User16921
ASIL C/D compliance is mentioned in the datasheet of the 1EDI2002AS gate driver IC but I assume there are some design criteria which must be followed in order to achieve this in practice?
Is any application data available regarding achieving ASIL D compliance with the 1EDI2002AS gate driver? I can't find anything on the website and am not getting any response from the online contact form.
Alternatively, do Infineon produce any other gate drive ICs which are geared towards ISO26262 / ASIL D compliance?
Kind Regards,
Grant
User16921
Thanks for your assistance.
I've tried contacting my local Infineon rep on 08/04/2019 and again on 30/04/2019 but haven't had a response yet.
Can you provide contact details for an application engineer?
Srivatsa
Moderator 5 sign-ins 50 replies posted 25 solutions authored
Pls contact the respective Infineon sales / application engineer in your region. They will assist you with further inputs.
User16921
