Rubacava
5 sign-ins First reply posted First like received
Hello, I am using 1ED3890 to replace and old analog 3 phase inverter system. The old system uses a kelvin emitter in addition to a power emitter to presumably trigger an error on high di/dt situations. Is it possible to implement this system for this driver? If not necessary, where should I connect the extra cable connection from the common emitter busbar?
The article in https://www.infineon.com/dgdl/Infineon-Application+Note+TRENCHSTOP%E2%84%A2+5+in+TO-247+4pin-AN-v01_... mentions in page 8 that: "The driver’s local ground, referenced to the auxiliary emitter, must be isolated from the power ground. This is mandatory to prevent shortening pins E1 and E2". How can I achieve this ground isolation? I'm already using an insulated bipolar supply with 15V ~ -5V.
AZIZ_HASSAN
5 likes given 250 sign-ins 100 solutions authored
1) There is a provision of DESAT current shoot through protection in the device.
2) Regarding your second query of emitter connection. It simply means that driver ground needs to be connected to Kelvin emitter of the device only. Rest your supply of bipolar is fine.
Thanks and regards,
AZIZ
AZIZ_HASSAN
May I know what do you mean by error on high di/dt.  It is overcurrent error ?
Thanks and regards,
AZIZ
Yes I mean overcurrent protection.
AZIZ_HASSAN
Thanks and regards,
AZIZ
Thanks for the reply. One other thing I want to ask is if active clamping is optional for bipolar supplies?
Kind regards.
AZIZ_HASSAN
Yes its optional and some times customers use both.
Thanks and regards,
AZIZ
Rubacava
Thanks you for the answers.
