In 1ED3461MU-12 driver IC, RDYC Pin can be used as a input as well as output but in datasheet output current has mentioned but input current not mentioned in it. I wanted to know the input current for RDYC pin.
Thank you for posting at Infineon community.
I clearly understand that the maximum output current of RDYC logic pin is given as 10mA, and input current is not given. For input current, as long as you connect the pin to maximum 6.5 V with proper pull up resistor (please refer to data sheet circuit diagram), the IC will work fine.
Another reason is, these pins have internal high impedance. So, as long as you adhere with prescribed voltage and resistor value, the IC will work fine.
I hope you understood.
BR,
AZIZ HASSAN
BR,
AZIZ HASSAN
