- Email to a Friend
Dear Sir,
May I know we can use 1ED31xxMU12H with SI/SIC MOSFET to design high switch? please help advise, thanks!
- Email to a Friend
Hi @KUOWENYUNG,
Thanks for posting your query in the Infineon community forum.
with the reference to the picture you attached. it has a unipolar supply (+15V and ground(F))
so I would suggest going with the below option for better design
1ED3122MU12H single-channel isolated gate driver with 9A typical sinking, 10A sourcing peak output current, and 3A Low-level clamp peak current in DSO-8 package with large creepage distance (>8 mm) for IGBTs, MOSFETs, and SiC MOSFETs.
1ED3122 offers an active Miller clamp, accurate and stable timing, active shutdown to ensure a safe switch off-state in case the output chip is not connected to the power, and short-circuit clamping to limit the gate voltage during a short circuit. The driver can operate over a wide supply voltage range, either unipolar or bipolar. It has Integrated filters to reduce the need for external filters
I understand that you want 2 resistances separately for RGon & RGoff.
The same can be implemented with 1ED3122MU12H also. please check the below link and a picture.
Malleswararao
- Email to a Friend
Hi @KUOWENYUNG,
Malleswararao
- Email to a Friend
Dear Sir,
thanks for your advise.
Currently, I was test IMW120R060M1H with 1ED3121MU for high switch, and have two phenomena need you help!
- Current overshoot/undershoot during VGS turn-off.
- Current overshoot with VDS drop when VGS turned off.
- Email to a Friend
hi @KUOWENYUNG ,
For more analysis and to understand clearly, may I know you load details
like
1. type of load and its characteristics.
2. what is your switching time period?
3. Is there any difference in circuit for both phenomena you mentioned.
Malleswararao
- Email to a Friend
Dear Sir,
1. the load step is 5V/1A by resistor 5 ohm
2. the switch type is randomly
3. there is same circuit for both phenomena
kind Regards,
Kuo
- Email to a Friend
hi @KUOWENYUNG ,
can you share voltage and current wave forms across the load.
and what is the probe you are using?
how much is the probe capacitance?
Malleswararao
