Gate Driver IC's
twuerffel
New Contributor
Dear Infineon Support,
I am currently designing with the BTF3035EJ chip and have purchased the Demoboard BTF3xxxEJ (PN: BTF3035EJDEMOBOARDTOBO1) to validate the chip for my function. The Firmware engineer I'm working with and I would be very interested in the zip package mentioned in the datasheet that supposedly contains Demoboard_Aiko_Universal.ino Arduino example code. I had submitted a support request previously to no response. I was able to find the GUI of the same name in a separate product's downloads page, but not the Arduino Sketch.
It was not sent with my purchase confirmation (and perhaps that's my mistake for ordering through mouser), nor is it anywhere in your downloads or available anywhere on the vast internet.
Can I be provided with the .zip file that is supposed to come with the Demoboard BTF3xxxEJ/BTF3035EJDEMOBOARDTOBO1
Pablo_EG
Hello twuerffel,
The distributor should have provided you with the .zip file in the first place.
However, we can help you here and provide it to you directly.
I attached the .zip file, which includes:
-.ino code example. This will only work with Arduino UNO.
-.exe GUI executable. This is used to easily send commands to the controller.
The code example can be used with different demo boards.
This is why, in your case, you have to use the GUI and select BTF3xxxEJ from the drop-down list.
Select the COM port in which the Arduino is connected.
Press start and use the GUI to perform different functions.
I hope this solved your problem.
Pablo
Pablo_EG
Hello twuerffel,
Thank you for posting on Infineon Community.
We understand that you require the zip file containing the .ino example code.
I deeply apologize for your support request not being answered.
We have received your request this time, and we will try and get your .ino example code.
I will contact you as soon as I have an update.
Pablo
Pablo_EG
Hello twuerffel,
Pablo
twuerffel
New Contributor
Pablo,
Thank you very much. This does solve my problem, and you can close this thread.
Top labels
