Replacement from S6E1C32C0AGN20000
TeMa_2997106
Level 6
Level 6
Distributor - TED (Japan)
10 likes received 10 solutions authored 250 replies posted
I use S6E1C32C0AGN20000 in the current model.
I would like to continue using it, but it does not get immediately because it has long lead time. I think it replace the following available (shorter L/T) devices:
S6E1C11C0AGN20000
S6E1C12C0AGN20000
S6E1C31C0AGN20000
I would like to use the external protection circuit of S6E1C32 as it is. Is it possible? If the noise resistance performance and I/O electrical characteristics are different, I will change the circuit, so please tell me what is different.
I see the datasheet, I couldn't find any difference.
Tetsuo
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
Hello Tetsuo,
These are differences in memory size and USB, not differences in electrical characteristics.
You can use the same circuit.
Roy Liu
Roy_Liu
Hello Tetsuo,
Roy Liu
TeMa_2997106
Level 6
Level 6
Roy-san,
Is the protection circuit in the MCU also the same?
Is there anything I should be aware of?
Tetsuo
Roy_Liu
Tetsuo-san,
Yes, the protection circuits in the MCUs are also the same. I can't think of anything else should be aware of.
Roy Liu
