FM0+, FM3 & FM4 MCU
SuSi_4695316
New Contributor
I am designing a controller around S6E2GM6J0AGV2000A. When using USB flash programming there is a pin, P22/SOT0_0, which selects the external oscillator frequency. Is such an oscillator required for USB Flash programming, or with the device in general? If not, then where should the pin, P22/SOT0_0, be connected?
ShipingW_81
You can refer to the schematic of DVK FM4-176L-S6E2GM for the details of pin connection -
https://www.cypress.com/documentation/development-kitsboards/fm4-s6e2g-series-pioneer-kit-guide
ShipingW_81
