User17640
02:56 AM
- Email to a Friend
As the title says, Id like to know more about the sic diodes robustness during fast commutation.
Do you maybe have any documentation or papers i can find more info about this?
Thanks in advance!
Thanks in advance!
08:53 AM
- Email to a Friend
Do you mean SiC Schottky diode or the body diode of SiC MOSFET?
Both of diode have no constrains regarding fast switching.
08:53 AM
- Email to a Friend
08:53 AM
- Email to a Friend
User17640
11:21 PM
- Email to a Friend
Hi Yuan, thanks for your respond. My question was aiming for the body diode of the sic mosfet.
06:51 AM
- Email to a Friend
Yes, the body diode is fully verified with fast switching. We have reached to even 200V/ns, the diode has not problem.
07:00 PM
- Email to a Friend
thanks for comments, Yuan. Do fast switching mean body diode can be counterpart for hard current commutation ? no synchronic mode needed for customer control design ?
03:15 AM
- Email to a Friend
Hi Zhao,
hard commutation and use of synchronous rectification are topics that are not directly related.
The body diode of our CoolSiC-Mosfet is suitable for hard commutation, because it is a SiC-diode (contrary to body diodes of HV-Silicon Mosfets)
It is recommended to apply synchronous rectification, because the forward voltage drop of the body diode is quite high. But the effort to implement synchronous rectification is very low. Any standard PWM pulse pattern applied to a halfbridge configurations will provide synchronous rectification anyhow. The body diode (instead of the Mosfet channel) will only conduct during deadtime or when very high currents are applied. Hence for optimum benefit of synchronous rectification it is recommended to minimize deadtime.
