Diodes & Thyristors (Si/SiC) Forum Discussions
WTC
First reply posted 5 sign-ins Welcome!
Is there IFSM and TRR data for IDC28D120T8M and IDC21D120T8M diodes ?   Alternatively,  are there package parts or modules these diodes are used so I can just look at the datasheet.  Thank you.
Wibawa Chou
Guru_Prasad
25 likes received 250 sign-ins 50 solutions authored
Hello @WTC
Thank you for posting your question in the Infineon community.
The IDC28D120T8M and IDC21D120T8M are active and preferred parts.
The IFSM_max for IDC28D120T8M is 100A
The IFSM_max for IDC21D120T8M is 70A
The Trr value need be checked internally. I will check and come back to you
Thank you
Guru
Guru_Prasad
Hello @WTC
Thank you
Guru
WTC
Hi Prasad, any update on this topic ?  Thanks
Guru_Prasad
Dear @WTC
Still, I did not get the data from the Product line teams. once I receive I can provide you.
meanwhile, please raise the ticket in my cases.
Thank you
Guru
