Diode: Infineon's BAR6402VH6327XTSA1, according to the data sheet, the frequency is 1M-6GHz
Jinftry
First like received First question asked Welcome!
When performing a diode rectification test, given a sinusoidal input with an amplitude of 2V, the output voltage amplitude decreases as the frequency increases. But the range indicated in the data sheet is 1M~6GHz, does anyone know the problem?
Diode: Infineon's BAR6402VH6327XTSA1, according to the data sheet, the frequency is 1M-6GHz:
Waveform: Green: Vin, Yellow: Vo
When the input is 1MHz
When the input is 10MHz
Daisy_T
250 sign-ins 250 replies posted 25 likes received
Hello @Jinftry ,
Can you share the waveforms?
Daisy_T
Hello @Jinftry ,
