Dimensions of gate-drive socket on TT250N SCR module
dmattd
First like received First question asked Welcome!
When referencing the datasheet for SCR module TT250N, the "socket" space around the quick connect terminals (110X030) lack sufficient details concerning space for terminals that are fully shrouded.  If various terminal manufacturers and part numbers are recommended, that would be good to know.
Undefined socket spaceUndefined socket space
Akhil_B
250 sign-ins First question asked 50 solutions authored
Dear @dmattd
Good Day!!
Can you please elaborate your issue ?
If your query is related to the gate terminal contact spacing, from Infineon we directly recommend the gate pin connector too which is shown in below image.
Thanks & Best Regards,
Akhil Kumar.
Akhil_B
Dear @dmattd
Good Day!!
Akhil Kumar.
Akhil_B
Dear @dmattd
Please refer to the attached app note, chapter 10.8 and 10.9 for gate pin connections for more details.
https://www.infineon.com/dgdl/Infineon-Use_and_Installation_Manual_34mm_and_50mm_Solder_Bond_Modules...
Akhil Kumar.
Akhil_B
Dear @dmattd
Good Day!!
Please check and let me know if further support is required.
Akhil Kumar.
