Jun 06, 2013
01:46 AM
Jun 06, 2013
01:46 AM
Is it possible to use xSPY with Relax kit ???
I dont see any VCOM port when I plug USB cable to debbuger?!
What should I do pls?
Jun 09, 2013
02:32 AM
Jun 09, 2013
02:32 AM
Hi
before you can use the VCOM, the USB CDC driver has to be installed. This is part of the SEGGER driver package, but must be installed manually. It can be found in the SEGGER install path. watch out for USB CDC driver. In case, there is an old formware at the relax kit, which does not support VCOM, you can download the latest driver package from SEGGER website (http://www.segger.com/jlink-software.html). Firmware update will happen automatically.
Arno
Arno
Jun 09, 2013
11:06 PM
Jun 09, 2013
11:06 PM
Hi
I downloaded latest driver package and I installed it ... during installation - I selected CDC driver too. But now I still have no VCOM device in my Device Manager in windows 7.
I dont know what is wrong.
Please help.
Please help.
Jun 13, 2013
11:38 PM
Jun 13, 2013
11:38 PM
Maybe you have to install the CDC manually:
Look for ....\SEGGER\JLinkARM_V472\USBDriver\CDC in your program files folder and execute InstDriversCDC.exe.
This should install the CDC USB driver.
Jun 18, 2013
12:38 AM
Jun 18, 2013
12:38 AM
I did everything as you said. But still not working 😞
Jun 20, 2013
03:07 PM
Jun 20, 2013
03:07 PM
Sorry, but the VCOM CDC functionality is not supported by the Segger OBD using the XMC4500 as debugger chip which is used in the relax kits. The VCOM CDC functionality is only supported by the Segger OBD using the XMC4200 as debugger chip. The Segger OBD using the XMC4200 as debugger chip comes with all XMC1000 boot kits or with the latest XMC4400/ XMC4200 Hexagon kits. We plan to replace the Segger OBD of the relax kit with the same OBD as currently used on the other kits in a couple of months.
