webserver_4500_relax_kit example problem
HI,
i tried to change the index file of webserver_4500_relax_kit example and add some operation.
when i reload the web page in the navigator. the changes are not applyed.
i tried to clean the project and rebuilding but nothing happens
note:
i'm not using a microSd card.
Could you pls provide the change details?
Sophia
i tried to add another button to toggle the second led.
then i generated the fsdata.c and replace it in Dave/src/WEBSERVER_001/ but the demo page still appear !
help please !
Hello!
Did you already found the following post to use the internal memory for storing the webpage? There something to do before you can use it as you obviously want to.
http://www.infineonforums.com/threads/711-XMC4500-TIP-of-the-day-How-to-store-web-pages-in-the-XMC-f...
Hope it helps...
