Hello I'm using a XMC45 and an external flash IS25LP128F. My XMC communicate with a PC by modbus.
I would like to recover data from the flash by it.
to test the data transmission, I use strcpy(Holding_Register->strMsg, "OFF - ON");
definition:
typedef struct
chr8_t strMsg;
chr8_t strMsgtest[10];
} Data_Modbus_Holding_Register;
Declaration :
Holding_Register = (Data_Modbus_Holding_Register*)®_holding_buffer;
This solution work correctly, I recover data.
but when I use : strcpy(Holding_Register->strMsg, "OFF - ON"); OR Holding_Register->strMsg = "OFF - ON" OR Holding_Register->strMsg[0] = "OFF - ON" I don't arrived to recover data. Someone can help me ?
Pierre Gachet
DAVE™
Hi Pierre,
strcpy(Holding_Register->strMsg, "OFF - ON"); Could result in overflow, that could be your actual issue.
OR Holding_Register->strMsg = "OFF - ON" and Holding_Register->strMsg[0] = "OFF - ON" are not right way to access the structure variable.
This could resolve your problem.
Vasanth R S
Hi Pierre,
I did not understand the difference between the working code and non-working code from the explanation. Could you please list them as working code and non-working code in separate section for better understanding?
Vasanth
Hi Pierre,
Vasanth R S
