Mar 05, 2013
01:45 AM
Mar 05, 2013
01:45 AM
I have problem with app SDMMC001.
I want simply try this app ... so I created new Project with this app - and I put SD card to my Relax kit.
Then after run my program (which is written as well as in help for this app) - the program freeze in file startup_XMC4500.s
on row "Insert_ExceptionHandler HardFault_Handler"
Does anyone know what is there wrong?
PS: I tried look to example "webserver" - there I found interesting thing - this example is for relax kit - where
is used MCU XMC4500 F100K 1024 but in example is set XMC4500 F144 ... and in resource manager is probably wrong
assigned pins.
assigned pins.
02:14 AM
Mar 05, 2013
02:14 AM
Hi Koumak,
please try the example project "SLTH001..." (Help > Install Dave Apps/Example Library > DAVE Project Library Manger). This example shows how to access an SD-Card using the standard library (including FAT file system). Probably you have to reconfigure the the SDCARD pins (Manual Pin Assignment), because the example has been written for the hexagon kits.
Marillion
Marillion
