08:05 AM
Mar 15, 2013
08:05 AM
I have installed DAVE 3.1.6 on a notebook with Windows XP SP2. It seems to work well. I created a demo project with a PWMSP002(1.0.20) and a NVIC002(1.0.12). I checked "Enable at initialization" for the Compare Match Interrupt. But when I try to use "signal connection" I find nothing in the drop-down menu. Is there anything I can do?
thanks and sorry for my English.
Cat
Cat
07:52 PM
Mar 18, 2013
07:52 PM
Could you send us the .log file(s)? There could be multiple .log files.
The .log file can be found in workspace folder:
\.metadata\
(ex: C:\Temp\DAVE_CE_WS_v316\.metadata)
02:25 AM
Mar 19, 2013
02:25 AM
02:43 AM
Mar 20, 2013
02:43 AM
“Invalid path or solver eclipse exe path not found” was found in the .log file. Could you pls check whether the proper solver eclipse path is provided or not?
Go to >DAVE CE->Window->Preferences
Solver Eclipse Path (in Solver settings) should point to the solver eclipse path as shown in the "DAVE CE Preferences" window.
The Solver eclipse.exe is part of installation and can be found the installed path of DAVE CE.
06:58 AM
Mar 22, 2013
06:58 AM
the solver eclipse path in my DAVE CE->Window->Preferences is the same of your and the Solver eclipse.exe is in the indicated directory.
Cat
Cat
08:20 PM
Mar 26, 2013
08:20 PM
Hi Cat,
Would you pls check the followings:
1) Solver process Eclipse.exe is running?
Open Windows Task Manager and check eclipse.exe process is present in the Processes tab. To double check, right click on the eclipse.exe and click on “Open File location”. It should open the solver folder (see attached snapshot).
2) Port number is used?
By default DAVE CE uses 10070. If this particular port number is used by other application/process, connection to the solver process may not be established.
You can try with other port numbers (eg. 10900). The port number can be changed in the same preference page (refer to DAVE_CE_PreferencesWindow.jpg provided in previous post)
After changing the port the DAVE CE should be restarted.
BTW, would you mind to share your workspace? Are you using the latest DAVE CE provided in Infineon web site.
Sophia
Sophia
07:22 AM
Mar 27, 2013
07:22 AM
Hi Sophia,
I'm using the DAVE CE 3.1.6 version.
Eclipse.exe is not running, I can not find it in the Task Manager.
I changed the port number and restarted DAVE CE but eclipse.exe is still not running.
Cat
Cat
11:36 PM
Mar 27, 2013
11:36 PM
Hi Cat,
Could you pls share the complete workspace directory & the OS your are using?
Sophia
Sophia
09:00 AM
Mar 28, 2013
09:00 AM
Hi Sophia,
yes but I am not sure of what you mean. Could you please tell me what should I do for share the complete workspace directory?
My OS is Microsoft Windows XP Sp3 and DAVE CE is located in C:\DAVE-3.1
thanks
Cat
thanks
Cat
10:48 PM
Mar 31, 2013
10:48 PM
Hi Cat,
The “complete workspace directory” is referring to the full path of workspace folder located (ex. C:\Temp\DAVE_CE_WS_v316) which can be defined by user during launch of DAVE CE.
Sophia
Sophia
12:28 AM
Apr 08, 2013
12:28 AM
07:03 PM
Apr 09, 2013
07:03 PM
Hi Cat,
The ".metadata" folder is missing from the workspace. This folder contains the debug information as I mentioned before. You did sent us the .log file which should be found in workspace folder (\.metadata\). I'm wondering where it is located?
Sophia
Sophia
01:44 AM
Apr 10, 2013
01:44 AM
