03:00 PM
Mar 31, 2014
03:00 PM
hello,
we're working with an xmc4500 relax kit for quite a while now and it seems that there are some parts in your code, that shouldn't be there. Functions we already deleted appear in the debugger-window. Also there are a few errors while processing we can't fix, because it seems like the code uploaded to the µC is not the one we've got in the source-files. It looks like it contains some old parts which we already deleted.
02:05 AM
Apr 01, 2014
02:05 AM
Would you be able to provide your project (together with the log files from .metadata folder) for our analysis? At the same time, highlight the extra portion which has been removed before but appears in the debug view.
Sophia
Sophia
05:33 AM
Apr 01, 2014
05:33 AM
How can i send you my project?
11:28 PM
Apr 01, 2014
11:28 PM
Would you mind to upload it in the forum?
BTW, is this project built on DAVE 3.1.6? Have you tried to import it into the later versions DAVE eg. 3.1.8 and run?
Sophia
Sophia
07:51 AM
Apr 05, 2014
07:51 AM
I use the later versions DAVE eg. 3.1.8 and still problem
