03:02 AM
Jul 16, 2013
03:02 AM
Hi ,
I'm starting using Dave3 and i found it wonderfull, my problem that i need to include a library which the path into the project.
thanks for help;
thanks for help;
04:19 AM
Jul 16, 2013
04:19 AM
Aaron
- Select 'Project' menu (top of screen)
- Select 'Active Project Properties'
- Select 'C/C++ Build'
- Select 'Settings'
- Select 'Tool Settings' tab
- Select 'ARM-GCC C Linker'
- Select 'Libraries'
- Click on 'Add' (+) button in 'Library search path (-L)
- Enter 'Directory' path
Aaron
