10:30 PM
Mar 28, 2016
10:30 PM
Hello ,
Is there any example or DAVE component how to use the ambient light sensor?
regards ,
Allan
regards ,
Allan
Labels
Jun 22, 2016
07:58 AM
Jun 22, 2016
07:58 AM
Hi Allen9,
The ambient light sensor circuit output is an analog voltage, so you read this signal with an ADC on the XMC1200.
This analog signal is on pin 2 of the 60 pin connector, and comes into the XMC1200 on port P2.11. If you are using DAVE v4 with the APPS, then you can use an ADC app to read this input voltage.
See attached documents for schematic and additional information.
Best,
Rick
Best,
Rick
