May 16, 2013
01:26 AM
May 16, 2013
01:26 AM
with Dave 3.1.6 incl latest app&example lib update, my App Selection View remains empty - even when opening an existing Dave-CE project or creating a new one.
Pls advise.
Pls advise.
03:17 AM
May 16, 2013
03:17 AM
Assume that you are not the 1st time installing Dave and the App Selection View was not empty before. Did you empty the local library store or create a new one before updating? You may refer to the previous post on how to keep different local library stores (http://www.infineonforums.com/threads/390-Fail-apps-download).
Sophia
Sophia
May 16, 2013
06:25 AM
May 16, 2013
06:25 AM
Hi Sophia,
thanks for your response.
What do you mean with "empty the local lib store"? Delete the contents of the D3LibraryStore folder?
I renamed D3LibraryStore to sth else and created a new, empty D3LibraryStore folder. Then I restarted Dave3. Check for updates delivered "no updates were found" and my problem with empty App Selection View persists.
08:48 PM
May 16, 2013
08:48 PM
Could you pls provide the snapshot of the existing contents in you D3LibraryStore folder (Go to >Help>Uninstall DAVE App/Example Library)? Attached is an example view.
Sophia
Sophia
May 17, 2013
03:59 AM
May 17, 2013
03:59 AM
Uninstall DAVE App/Example Library, followed by re-install solved the problem.
Is the Uninstall procedure mandatory for each update or only as workaround in cases of empty Apps Selection view?
