06:59 AM
Mar 10, 2015
06:59 AM
Hi all,
I'm trying to make a program where I use SPI001 [1.0.24]. I want to manually manage the ChipSelect pin. Is that possible to do that with IO004[1.0.22]? If so, can you tell me how? Because I can't manual select a pint 0.2 in SPI001 AND IO004.
Thanks in advice
Thanks in advice
03:05 AM
Mar 11, 2015
03:05 AM
Do you mean this...?
BR,
Zain
BR,
Zain
06:17 AM
Mar 11, 2015
06:17 AM
Thanks for your reply. Yes I mean the Manual Pin Assigment. But I ment to couple the ChipSelectA pin with the pin selected with IO004. But I already managed to solve the problem.
Best regards.
Best regards.
