03:37 AM
Apr 30, 2013
03:37 AM
The autogenerated code puts this line:
WR_REG(PORT14->PDISC, PORT14_PDISC_PDIS0_Msk, PORT14_PDISC_PDIS0_Pos, PORT_PDISC_PDIS-1); /* P14.0 : PORT14_PDISC_PDIS0 */
in the function void DAVE_MUX_PreInit(void) of DAVE/Generated/src/DAVESupport/MULTIPLEXER.c file.
The compiler gives the error:
../Dave/Generated/src/DAVESupport/MULTIPLEXER.c: In function 'DAVE_MUX_PreInit':
../Dave/Generated/src/DAVESupport/MULTIPLEXER.c:278:3: error: 'PORT_PDISC_PDIS' undeclared (first use in this function)
Changing the line as follows:
WR_REG(PORT14->PDISC, PORT14_PDISC_PDIS0_Msk, PORT14_PDISC_PDIS0_Pos, PORT_PDISC_PDIS1); /* P14.0 : PORT14_PDISC_PDIS0 */
the compilation ends with no error.
Could you explain me if this is a bug of DAVE's code generation function and if my solution is correct?
02:28 AM
May 07, 2013
02:28 AM
Hi sitael,
Are you using IO001[1.0.10]? Is this pin (P14.0) used as analog input? Which function is this pin used for? Per helps you can give some more details on the project configuration eg. snapshot of "S/W App Connectivity View"?
Sophia
Sophia
09:33 AM
May 07, 2013
09:33 AM
I'm not using IO0001 and P14.0 in my project. You will find attached the screenshots of the pin assigniments (part 1 and 2) with the components used.
10:34 PM
May 07, 2013
10:34 PM
Hi sitael,
I'm wondering how you can get those port configuration for P14.0 if you are not using P14.0 in your project? Perhaps it is used by other Apps? Could you pls provide a resource mapping report (click "Resource Mapping Information" button on DAVE CE tool bar) so that we are able to know all the Apps you used in the project? BTW, did you use the latest released apps library? If not, could you pls try with the latest version and update me if the problem till exists. Thanks.
Sophia
Sophia
04:33 AM
May 08, 2013
04:33 AM
11:36 PM
May 08, 2013
11:36 PM
Hi sitael,
From the Resource Mapping table and Pin Assignment table you provided, it is confirmed that P14.0 is not used in this project. So it is impossible to get port configurations for P14.0 by using DAVE 3 auto-code generation function. I've tested and confirmed this by creating a fresh project with all the Apps you used. Pls try to create a fresh project with latest version apps. If the problem still exists, send us the whole project. Thanks.
Sophia
Sophia
02:29 AM
May 09, 2013
02:29 AM
Hi sophia,
Do you know how to generate a new project directly from the Resource Mapping files exported from the previous project (without manually adding all components and pins again)?
May 09, 2013
10:19 PM
May 09, 2013
10:19 PM
Hi Sitael,
It is a good idea to extract the old project information/setup into a new DAVE version project.
Unfortunately, the present version of the DAVE3 does not support such functionality at the moment.
