09:20 AM
Apr 15, 2013
09:20 AM
In my application (created with DAVE3) I'm using two PWMMP001 components. During the compilation the following error is generated four times:
"The Required resource app is not found in the app store app/ccu8pwmlib/*".
Anyway the application works and I can debug and generate PWM signals.
Could you explain me if this error means that there is something wrong in the Library and how I can solve it?
12:36 AM
Apr 16, 2013
12:36 AM
Hi sitael,
Are you using the newly released DAVE Apps? Pls refer to "Information about updates" for the details, thanks.
Sophia
Sophia
Apr 17, 2013
04:29 AM
Apr 17, 2013
04:29 AM
Hope you might have selected the second option -"Ignore Missing Apps and Build SW App Connectivity".
This is not an compilation error. So, it will not harm the functionality of the App.
This would be fixed in the next update of the DAVEApps Library.
