DAVE™ Forum Discussions
I'm using DAVE to create an application using ETH001 component for the In XMC4500 Relax Kit where there are pins dedicated to ethernet.
When I select Manual Pin assignement for eth_tx_en pin, it is not possible select the P2.5 pin of the board but only the P0.4 or P1.12 pin.
The same problem happens for other ethernet pins.
How I can solve this?
Marillion
First solution authored First like given 10 replies posted
Hi Sitael,
this is working fine in my setup.
Can you please send me your zipped DAVE project.
Export function inside Dave is here: File > Export > Infineon > DAVE Proj.> Select Archived Files > Browse
Marillion
