Apr 22, 2021
10:31 AM
Apr 22, 2021
10:31 AM
Good day to all,
I'm currently working on a project using an XMC4500 Relax Kit with DAVE4, a CAN transceiver(Rx pin 1.5 and Tx pin 1.4) and a CAN Interface VN1610 from Vector connected to the PC (software "CANalyzer" from Vektor).
For now I have a working program that gets the values of Tension, current, temperature, time, etc... visualizes them on a web server like in the picture "HTTP_WEBSERVER" and refreshes the values each 2 seconds.
Now I want to visualize these values on the software "CANalyzer", so send them through the CAN interface instead of the HTTP server.
I searched a lot online for examples of CAN transmission but none of them would give me any signal of connection on the Software.
Can anyone help?
There are also links to download the project and the pictures.
Link to Project: https://drive.google.com/file/d/1B9qPGdfgzB2E6Zc5NZBZdc0SGeKwRk4w/view?usp=sharing
Links to pictures: HTTP_WEBSERVER: https://imgur.com/1lKLSkT
CAN Transceiver: https://imgur.com/hBdoqG7
CAN interface: https://imgur.com/lMbg3m8
XMC4500 Relax Kit: https://imgur.com/7tDlGXn
Thank you in advance.
Fares
Can anyone help?
Fares
01:47 AM
Apr 23, 2021
01:47 AM
Hi Fares,
If you are searching for a can examples, kindly download the XMClib . Here inside examples there are CAN transmitter, receiver and loopback examples for your reference. I hope this will be helpful to start with.
Vasanth
Vasanth
01:47 AM
Apr 23, 2021
01:47 AM
Hi Fares,
Vasanth
Vasanth
