I'd like to sometimes use continous pulse mode (single pulse), and sometimes switch to single shot mode. Is that possible?
I did not find proper function from generated PWMSP002 files.
On PWMSP002.h the mode is specified in
typedef struct PWMSP002_HandleType
/** This parameter is used to store whether CCU8_CCy slice is in single shot
* mode or in periodic mode
const uint8_t kTimerMode;
But is seems inchangeable. Any advice?
The single shot mode is controlled by CCU8yTC.TSSM bit. You may try to configure it in main.c (eg. CCU80_CC80 -> TC |= 2;)
BR,
Zain
