DAVE™ Forum Discussions
Is DAvE only zipping the current project directory, nothing more?
In other words, can i use
zip -r projectname.zip projectnamedir
and use external project management tools, in the simplest case makefiles and shell scripts if the project is located on a Linux server.
HEINZ
Hi Heinz,
The DAVE project import/export function must be used in order to keep all DAVE relevant information according to "DAVE TIP of the day: Infineon DAVE Project import and export functions".
BR,
Zain
WilhelmBrezovit
Welcome! 10 replies posted 5 replies posted
Additionally I would always select „Select Archive File“ = zip File (makes it easier because you only get one file). Note: Do not unzip the zip file.
Zain wrote:
Hi Heinz,
BR,
Zain
But why? And what else is in the zip file?
I like to use a zip exported project, do some changes in it using a script,, and generate a new zipped project.
I only like to know where additional information stored. To have a look at it and to see if it is relevant for the new to genarte archive.
Having a computer, it makes no sense to always use a keyboard and mouse for tasks that can be automated.
(Yes I'm a engineer, not only programmer).
Heinz
Hi Heinz,
Would you mind to provide some more details on what kind of changes you would like to make in exported DAVE project?
Sophia
sophia wrote:
Hi Heinz,
Sophia
In the simplest case exchanging some header files with constant definitions,
or edit such files using sed, awk or other tools.
More advanced, removing some source files and create a .a lib from the object files, afterwords clean the project.
Of course in this case the starting project is not cleaned.
Anyway, I only want to know what "export" does, nothing more.
Heinz
Hi Heinz,
As long as you don't make any modification to DAVE/Model folder, should not have any problem.
Sophia
These are good news. Thanks Sophia.
