I'm trying to run the sample "200 W Transmitter_Firmware" that comes with "Würth Elektronik 200W Development Kit",
but I get the following error.
What are the possible causes?
<Device used>
・Würth Elektronik 200W Development Kit
<Debugger>
・XMC™ Link
<Tool>
・Dave™ 4.5.0
From the Dave error, seems to be the device is not powered or there is some issue with cable. Can you make sure that. Also can you try to get information on the guidelines on how to setup the hardware before programming from Würth?
Vasanth
I am having the same error here and am working on the same debug board. Did you ever manage to solve this problem/get information from Wurth Elektronik on how to debug the board?
I got a flashing instruction from Würth Elektronik.
I recommend you to email to wirelesspower@we-online.de.
Is there any way that you could please send the flashing instructions somehow? I've attempted reaching out to Wurth Elektronik before and they have not been great about responding to my emails.
Hi ,
Are you find the instruction ?
