11:41 PM
Nov 06, 2014
11:41 PM
I am very new to DAVE Platform.
In my project I need microsecond timer (SYSTM002) and ETH004 (which uses SYSTM001). When I tried to add SYSTM002 after adding ETH004 DAVE gives error message "HW Resources not sharable..."
Is there any method to use this two timer same time or is there any method to create microsecond timer without using SYSTM002 ?
I also have another problem with DAVE 3. When I use my computer with Turkish Regional Setting (Windows 7 Prof.) DAVE 3 does not add any App to project. If I change Regional Settings to English everything works well. Is there any solution related Regional Settings and DAVE 3?
Adem
Adem
01:40 AM
Nov 07, 2014
01:40 AM
Hi Adem,
You should be able to use CCU4 to create your own timer. Take a look on "Periodic microsecond timer".
I have no idea on the relationship between Regional Settings and DAVE. From "Build problem on Windows 7", it seems DAVE project can be built on Windows 7 with Russian language pack by disabling Kaspersky Anti-Virus.
BR,
Zain
BR,
Zain
08:53 AM
Nov 08, 2014
08:53 AM
Zain wrote:
Hi Adem,
BR,
Zain
Many thanks Zain,
I will try to use CCU4.
