Nov 03, 2016
08:19 AM
Nov 03, 2016
08:19 AM
is there a how to for using DAVE together with an version control? I want to use SVN for version control and now the question is which files have to be added to the version control and which one are generated. Is there a descrition?
Thanks for Help
Fabian
Thanks for Help
Fabian
02:59 AM
Nov 07, 2016
02:59 AM
You can exclude the usual suspects Debug and Release.
You might also exclude "Dave" which contains the code generated by the apps (I haven't tried that)
Nov 07, 2016
07:10 AM
Nov 07, 2016
07:10 AM
For version control, I would grab everything in the project directory as well as the Dave, Libraries, and Startup folders. We also have a DAVE_modified directory where we tweak some of the XMC library files that I get as well. I skip .settings folder.
In the Debug and Release directories, I check in just the makefile and .mk files. This allows me to do automated/nightly builds without the DAVE IDE running. The script I have sets up the environment, runs make, and logs all output to a file. If you don't plan on anything like that, the Debug and Release can be skipped completely.
