05:26 AM
Oct 22, 2013
05:26 AM
we are trying to run DAVE inside a virtual machine to roll it out on a larger number of desktop computers at a university. Unsupervised installation is highly desired and would keep the administration effort on a managable level.
In our first test, everything was fine with DAVE 3.1.6 and a manual installation inside the virtual machine.
In the current setup, DAVE and the Segger Tools were installed separately.
DAVE 3.1.8 is running properly and the ARM simulator works. The Segger J-Link 4.74 Tools communicate with the XMC4500 Relax board. However, the Tasking debugger in DAVE crashes with an error that it could not find the Segger tools.
Is there a config file where the path to Segger can be set after the installation?
Matthias
Matthias
02:39 AM
Oct 23, 2013
02:39 AM
Hi Matthias,
The tasking debugger reads segger dll path form windows registry:
The latest installed version can always be found at: HKEY_CURRENT_USER\Software\SEGGER\J-Link\InstallPath
Perhaps you need to check & update this in the Virtual machine...
Sophia
Sophia
06:01 AM
Oct 31, 2013
06:01 AM
Hi Sophia,
thanks a lot! The tools are working properly together now.
Matthias
Matthias
