03:28 AM
Jul 13, 2014
03:28 AM
I don't know why, but I do get this linker message very often in XMC4000 applications.
What I do, is specifying it in the Linker script. This helps but might have side effects.
Who can tell me who is referring to it? What is the best way to avoid this linker message?
Heinz
Message is:
In function '__libc_fini_array':
fini.c:(.text.__libc_fini_array+0x42): undefined reference to '_fini'
DAVE is 3.1.10
Heinz
Message is:
DAVE is 3.1.10
12:53 AM
Jul 14, 2014
12:53 AM
The problem was calling exit() from libc because the application was inherited from a Linux CANopen project.
I added my own version of exit().
Heinz
02:59 AM
Jul 14, 2014
02:59 AM
Hi Heinz,
Can you provide the details on where and how do you call the exit()? Would you mind to share your own version of exit() or even your project?
Sophia
Sophia
02:57 AM
Jul 15, 2014
02:57 AM
sophia wrote:
Hi Heinz,
Sophia
Hello Sophia,
for all our CANopen stuff we first develop the protocol stack and applications on a Linux machine.
Later on do test portability we try the same software on different embedded platforms like XMC using DAvE.
The Linux application typically calls exit(errorcode) if something goes wrong to finish a single program.
On the embedded platform you can not end a program. But what you can is specific to the hardware you have.
In he simplest case exit() can disable all interrupts and run an endless loop. If some LEDs are available,
they can be used to show the reason for stopping by using different LEDs, different colors or blinking sequences.
That said, the simplest version can be
void exit(int reason) { while(1); }
regards
Heinz
10:44 PM
Jul 16, 2014
10:44 PM
Hi Heinz,
The root cause is that the exit() function uses a NewLib routine "_fini" which needs to be defined in LibcStubs.c. Currently it is missing.
Pls follow up the eTicket 671808605.
Sophia
Sophia
03:03 AM
Jul 27, 2014
03:03 AM
wrong Ticket Link ?
03:08 AM
Jul 27, 2014
03:08 AM
I'm not able to use the "Tickets Manager" and search for a specific Ticket Id. :mad:
02:23 AM
Jul 30, 2014
02:23 AM
Hi Heinz,
You should be able to search for a specific eTicket by input the id in Search field:
In addition, thank you very much for the feedback. The ticket link has been corrected.
Sophia
Sophia
11:49 AM
Aug 09, 2014
11:49 AM
Hello Sophia,
searching for the ticket Id only works if I'm NOT logged in. Which is a bit strange.
Heinz
Heinz
09:57 PM
Aug 10, 2014
09:57 PM
Hi Heinz,
You need to check "All tickets" as it is not submitted by you.
Sophia
Sophia
