DAVE™ Forum Discussions
I have 12 closed projects and 3 open projects in my work space.
If I want to switch between my open projects I can right click on a project folder and set it as the active project. The s/w app connectivity view updates properly. Code generation, building and debugging work fine as well.
The project is apparently active but it is not displayed properly in the project explorer:
Usually the word -ACTIVE appeared next to the project name, but it is not displayed anymore (neither next to another project name).
Furthermore the appearance of the directory "model" has changed:
471.attach
This issue persists since a couple of days.
I am using a version control system, so I am refreshing my project files frequently. Could this relate to the changed appearence?
Did someone else come across this deactivated(?) model view?
Georg_Huba
You probably have switched to the ”Project Explorer” view. The active project is only highlighted in the “C/C++ Projects” view.
Hello Georg,
thank you very much. It seems like I have changed the view by mistake. 🙂
