Dec 04, 2014
10:30 PM
Dec 04, 2014
10:30 PM
Hi all,
I have simple program in XMC4500. It is only one file Main.c
How can I translate it without IDE (without DAVE)?
my assumption:
1) create new empty folder e.g. "MySourceCode"
2) create Main.c with some code
3) copy there arm-none-eabi-gcc.exe, arm-none-eabi-objcopy.exe, make.exe ... (I do not know what else is needed) ... from ..\DAVE-3.1.10\ARM-GCC\bin\
4) create makefile, ... .ld file (I do not know what else is needed)
5) execute these files (with some parameters ... from command prompt... finaly from .bat)
6) get ... .hex file (which is possible to download to XMC4500)
Is this process possible?
Please help.
BR
Koumak
my assumption:
Please help.
BR
Koumak
01:34 AM
Dec 05, 2014
01:34 AM
Hi Koumak,
Yes, it is possible. But at least you need "ARM-GCC" & "CMSIS" folders if the code is built for XMC.
For step 3, use gcc.exe. Refer to DAVE IDE "ARM-GCC C Compiler" Command setting and options (Go to: >Project>Active Project Properties>C/C++ Build>Settings>Select "ARM-GCC C Compiler" in "Tool Settings" tab)
For step 4, use ld.exe. Refer to DAVE IDE "ARM-GCC C Linker" Command setting and options (Go to: >Project>Active Project Properties>C/C++ Build>Settings>Select "ARM-GCC C Linker" in "Tool Settings" tab)
You can combine steps 3 & 4 into a makefile.
Sophia
Sophia
Dec 18, 2014
12:52 AM
Dec 18, 2014
12:52 AM
Hi Sophia,
I am beginner in this branch.
Can you provide a simple example please ?
(or/and little more detailed description)
I need translate only one simple file (main.c) ... in this way (without DAVE) ... create "hex" file.
Koumak
Koumak
