Jan 30, 2015
02:46 AM
Jan 30, 2015
02:46 AM
Hello.
I am working with the Hexagon Starter Kit. I used it some months ago and I think it worked quite fine. But now I have resume my work and I am having problems with the debugger.
It stops at any point, as if there is a breakpoint, but there is no breakpoint there. Maybe I placed a breakpoint but now it is removed. Is it possible that a breakpoint remains somehow active even after removing it?
Also the debugger gets blocked at some points, for instance when sending a CAN message. Sometimes I get this message:
If I run the program without the debugger, it works properly.
At this moment the debugger is a completely usseless tool for mi. 😞
Attached you can find the sample project I am using (the Debug folder is removed because of its big size).
Any help will be wellcome.
Thanks in advance,
José Luis.
Thanks in advance,
José Luis.
07:09 AM
Feb 01, 2015
07:09 AM
Maybe you can try this:
http://www.infineon.com/dgdl/winIDEA_open_DAVE_Install_QuickStart_1-0.pdf?folderId=5546d4694909da480...
it is another debugger plugIn. I didn´t ry it by myself but maybe it is more stable. I heard it should have more features.
There is also a possibility to use winIDEA Open. I am using this. It is more stable and has more features. Google for winIDEA Open.
Thomas
Thomas
Feb 01, 2015
11:56 PM
Feb 01, 2015
11:56 PM
Thank you Thomas.
The link of your post is for winIDEA. I wonder if you wanted to mention a different one. Anyway, I am installing winIDEA right now.
José Luis.
José Luis.
01:53 AM
Feb 05, 2015
01:53 AM
Hi José,
in the meantime i also installed the winIDEA Open plugin. It works fine for me. Till now i worked with a winIDEA Open stand allone installation. I just had a problem, that i had to setup the debugmode (SWD) manually. Once i did that, everything works fine and stable. So let me know if it works for you as well. I am currently working with the XMC2Go board.
Thomas
Thomas
